Hola gente como estan, bueno ahora que ya tengo tesles quiero introducirme en el mundo de la astrofotografia eso si por ahora tengo un teles hokken 76/700 pero en enero voy por el sw esplorer , y mi pregunta es si esta camara Nikon Coolpix L110 va bien para la astrofotografia gracias.
Marcos.
podrias poner mas especificaciones de la camara?
y alguna foto de paso.
ok ahora pongo fotos y detalles.
Bueno esta es la camara saludos. :D
Effective pixels
12.1 million
Image sensor
1/2.3-in. CCD; total pixels: approx. 12.39 million
Lens
15x zoom NIKKOR; 5.0-75.0mm (35mm [135] format picture angle: 28-420mm); f/3.5-5.4; Digital zoom: up to 4x (35mm [135] format picture angle: Approx. 1680mm)
Focus range (from lens)
50cm (1 ft. 8 in.) to infinity (∞); Macro close-up mode: 1cm (0.4 in.) to infinity (∞)
Monitor
7.5cm(3-in.), approx. 460k-dot, TFT LCD with anti-reflection coating
Storage media
Internal memory (approx. 43 MB), SD memory cards*1
Image size (pixels)
4000 x 3000★ (12M), 4000 x 3000 (12M), 3264 x 2448(8M), 2592 x 1944 (5M), 2048 x 1536 (3M), 1024 x 768 (PC), 640 x 480 (VGA), 3968 x 2232 (16:9), 1920 x 1080 (16:9)
Vibration Reduction
Combination of image-sensor shift and Electronic VR (still images)
Electronic VR (movies)
ISO sensitivity
ISO 80, 100, 200, 400, 800, 1600, 3200*2, 6400*2, Auto (auto gain ISO 80-800)
Interface
Hi-Speed USB
Power sources
Four FR6/L91 (AA-size) lithium batteries (supplied), four LR6/L40 (AA-size) alkaline batteries (optional), four EN-MH2 rechargeable Ni-MH batteries (optional), AC Adapter EH-67 (optional)
Battery life *3
Approx. 840 shots with lithium, or 270 shots with alkaline, or 500 shots with EN-MH2 battery
Dimensions
(W x H x D)
Approx. 108.9 x 74.3 x 78.1 mm (4.3 x 3.0 x 3.1 in.) excluding projections*4
Weight
Approx. 406 g (14.4 oz.) with battery and SD memory card*4
Supplied accessories *5
Four FR6/L91 (AA-size) lithium batteries, USB Cable UC-E6, Audio Video Cable EG-CP14, Strap AN-CP21, Lens Cap LC-CP20, Software Suite CD-ROM
Optional accessories
Four LR6/L40 (AA-size) alkaline batteries, four EN-MH2 rechargeable Ni-MH batteries, Battery Charger MH-73, AC Adapter EH-67
* *1Not compatible with Multi Media Cards (MMC).
* *2Setting is available only for image sizes of 3M (2048 x 1536) or smaller.
* *3Based on CIPA industry standard for measuring life of camera batteries. Measured at 23°C (73°F); zoom adjusted with each shot, built-in flash fired with every other shot, image mode set to Normal.
* *4Method of noting dimensions and weight is in accordance with CIPA DCG-005-2009 guideline.
* *4Supplied accessories may differ by country or area.
Specifications are subject to change without any notice or obligation on the part of the manufacturer. February 2010.
y bueno en enero tendre este teles con montura robot ya para astrofoto lo requiere diganme si voy bien encaminado jeje saludos.
si que te sirve para empezar.......
vas a nececitar un adaptador para acoplarla al telescopio.
sabes cuanto tiempo podes tener el obturador abierto??
en esa camara o en general algo estoy mirando en el foro con respecto a eso , alguna otra camara me recomiendan a parte de esa masomenos 1400 pesos estoy pensando gastar
saludos.
por lomenos quiero que me tira un par de años jejeje con el equipo (tele y camara) asi dpues mas adelante voy por algo mejor el tema es que quiero empezar bien y no mal saludos
