Publicado 19 de Septiembre del 201113 a Hola a todos, me acaba de llegar el DVD doble cara del US Naval Observatory con el Catálogo UCAC-3, este catalogo sirve entre otras cosas para mejorar la alineacion de la montura haciendo "plate solving" con programas como el Elbrus, MaximDL, MaxPoint, etc. The UCAC3 is a high density, highly accurate, astrometric catalog of 100,766,420 stars covering the entire sky. Proper motions and photometry are provided for all stars. Positions are on the ICRS (International Celestial Reference System) and given for the epoch J2000.0.The UCAC3 is the third release of the ongoing UCAC project, designed to observe the entire sky over a magnitude range of 8 to 16, in the survey bandpass, which is between V and R. Observed positional errors are about 15-20 mas for the stars in the 10 to 14 magnitude range. The UCAC3 has a number of major differences with respect to the UCAC2. These differences include: complete sky coverage re-reduction of the pixel data with better modeling double stars are resolved to the limit of the data significantly improved photometry from CCD data slightly deeper limiting magnitude with larger number of stars/area reduced systematic errors of CCD observations the addition of several new catalogs for improved proper motions photometry in the B, R, and I bands from the SuperCosmos project minor planet observations have been sorted out identification of more high proper motion stars match with 2MASS extended sources and LEDA galaxies Los intersados me avisan y les hago una copia o vienen a la oficina y se lo copian. No lo subo al server porque son mas de 8 Gb de informacion. Saludos y buenos cielos! iOptron CEM70AG, iOptron GEM28ECAskar ACL200, Duoptic ED Pro 60, APO 90, Photo 90 5 elementosQHY600M, QHY294M Pro, QHY268C, QHY183M, QHY5III462CZelaya - Pilar - Buenos Aires - ArgentinaDuoptic - Espacio ProfundoMi Galeria de Fotos IG: @rfcontrerasb
Publicado 19 de Septiembre del 201113 a Ricardo me anoto para cuando vaya a buscar la montura. Saludos Jorge
Publicado 19 de Septiembre del 201113 a Autor Es 1 solo DVD dual layer. Lo mas practico es que traigan un pendrive o disco externo, mas rapido, mas barato. Olvide decir, sirve para los que hacen astrometria tambien.. Saludos y buenos cielos! iOptron CEM70AG, iOptron GEM28ECAskar ACL200, Duoptic ED Pro 60, APO 90, Photo 90 5 elementosQHY600M, QHY294M Pro, QHY268C, QHY183M, QHY5III462CZelaya - Pilar - Buenos Aires - ArgentinaDuoptic - Espacio ProfundoMi Galeria de Fotos IG: @rfcontrerasb
Publicado 19 de Septiembre del 201113 a Creo que puede intersearme... Seguro que si! jaja! gracias por el ofrecimiento Riky, iré por allí en cuanto pueda. Un abrazo
