Desde el 3 de Marzo se encuentra disponible la última versión del fantástico Cartes du Ciel (SkyChart v3.6), uno de los mejores y más completos programas de cartas celestes y control del telescopio (entre otras cosas), y como si fuera poco, es totalmente gratuito.
Entre las mejoras más importantes se encuentra la posibilidad de conectarse con los servicios de VizieR y poder descargar cualquier catálogo (total o parcial).
Esta es la lista de mejoras y agregados con respecto a la versión anterior (3.4):
Version 3.6
Interface:
* Change the way the “Show grid” buttons are working.
* Add “Show compass” button.
* Add distance measurement tool, add “Measure distance” button.
* Add chart legend. See menu Chart / Labels
* Add option to only show the meridian lines.
* Increase planet simulation up to 500 positions, no change for comets and asteroids.
* Can change the color for lines and nebulae from the catalog setting.
* Add Tirion constellation figures created by James Trogolo
Catalog and data:
* New default star catalog based on Extended Hipparcos to replace the BSC and Sky2000.
* Add user defined objects in catalog setting.
* New online Internet resources:
  * Add any catalog from Vizier, allow for full or partial download.
  * Search Simbad, NED, Vizier.
  * Link object detail to Simbad, NED, HyperLeda.
Projection mapping:
* Add Mercator projection.
* Cartesian and Mercator projection are rotated to the screen center for full sky coverage.
* Change the default projection to Tangent for FOV up to 90 deg. and Mercator for wider fields.
* Limit the use of Arc projection to 250 deg. FOV.
* Limit the vision of objects below the horizon to 180 deg. FOV.
Coordinates computation:
* Improved precision of the apparent coordinates (many thanks to P. Wallace for its help):
  * Star parallax
  * Take account of the radial velocity to compute the proper motions.
  * Light deflection by the Sun.
  * Extended time validity for nutation and aberration if using DE422.
* Compute the precession using “New precession expressions, valid for long time intervals, J. Vondrak, 2011”
* Compute DeltaT values from “Five Millennium Canon of Solar Eclipses, Espenak & Meeus, 2006”
* Extend the allowed date to +/- 200'000 years
Pictures:
* Improved precision in the display of FITS images by using WCStools. Can show the images with transparency.
Internet connection:
* Allow to use Socks proxy.
Este es el enlace al sitio web oficial:
http://www.ap-i.net/skychart/es/start
Que lo disfruten! :)
Salu2!
CDC 3.6 con estrellas e información del catálogo PPMXL en un sector del cielo:
gracias por la data, a mas de uno le va a venir bien este software...
Muchas gracias por compartir.
Pablo
Gracias, hay muchos usuarios de este soft tan completo
Gracias Néstor por la noticia:
Estos pequeños detalles hacen que EP sea insustituible. Ya lo instalé. Muchas gracias…
Saludos RGF
Ya lo pruebo!!! Gracias Néstor!!!
Hola Néstor
Gracias por el dato, me viene bien.
Gracias Nestor. :)
Un Saludo
Gracias amigos por pasar a comentar.
Me alegro que les guste. A mi personalmente me encanta este programa, y hace algunos años que lo uso, así que no duden en preguntar.
Un abrazo.
Nestor:
Muchas gracias por la info.
Según tu opinión: Cuál es el mejor tutorial de este programa, la ayuda del mismo o hay algo más.
Un abrazo.
