Hola a todos:
Acabo de descubrir que en ...
http://www.sharplesscatalog.com/Default.aspx
Tienen el catálogo de Sharpless, de nebulosas...
y en...
http://galaxymap.org/drupal/node/156
Los de Gum, RCW, Sharples y BSF...
Si los hacen trabajar junto con Simbad...
http://simbad.u-strasbg.fr/simbad/
Creo que bajo ningún punto de vista necesitaremos otros catálogos, al menos eso me parece.
¡Casi todos son para bajar, imprimir y con buscadores espectaculares!
Acá va como muestra la Seagull Nebula en Monoceros.
Sharpless SH2-296
Common Name Seagull Nebula
Constellation Monoceros
RA 7h 3m
DEC -11d 8m
Size 200
Shape Irregular
Brightness Bright
Object Type Diffuse Nebula
Type Emission
Other Catalog # IC 2177; LBN 1027; Gum 2
This large object is a common object among imagers and is also know by its common name The Seagull Nebula. SH2-296 is mainly the part that outlines the wing of the seagull but there is a lot of nebula in the area that does very well with the hydrogen-alpha filter. There are also a number of smaller Sharpless objects, but the other more common one imaged is known as SH2-292 which makes up the head. This object also responds very will to the Sulfur II and Oxygen III filter, so be sure to use those filters on this one. SH2-292 contains a small reflection nebula that can get lost in the H-Alpha channel, so a long RGB color series will help bring that back. This is a large object covering about three degrees, so you need a camera or telescope with a large field of view. It was published in Astronomy Magazine August 2007.
Aviso por las dudas que no los conozcan, así no les pasa como a mí, que andaba renegando con unas listas berretas...
Saludos RGF
sh2-296.jpg.96b5465b12e22b06bc2f866d0738
Muy buenos! El primero no lo conocia, el segundo lo utlizo a veces para buscar informacion de nebulosas esquivas y tal cual, complemento con el SIMBAD o Aladin. Totalmente recomendados los links y agendo el primero. Saludos!
Muy buenos links.
Gracias!
JC
