Publicado 21 de Julio del 201410 a Hola amigos Viendo algunas aplicaciones Android para celulares encontré esta que es gratuita por ahora pues esta probándose en versión Beta. Skycruiser es un software desarrollado con el fin de controlar telescopios Celestron Nexstar compatibles de forma inalámbrica empleando Bluetooth ® y GPS. (SkyWatcher) Después de la alineación que requiere el control de la mano, Skycruiser básicamente reemplaza el control de la mano del telescopio con control inalámbrico. El software requiere sólida familiaridad con el uso de la montura del telescopio conectado, su control de mano, teléfonos inteligentes Android y astronomía básica. http://www.requio.com/m/scmanual.pdf http://app.sina.com.cn/appdetail.php?appID=575288& Essential Features * Writes GPS coordinates and time to the hand control * Writes saved coordinates and system time to the HC * Directional slew in 9 speed rates, parking modes * Azimuthal and equatorial tracking modes * Star chart down to magnitude 6.4 with GoTo * Manual input of equatorial coordinates with GoTo * Object database with GoTo buttons: - 88 Constellations - 3833 Stars with designations (SAO, HIP, HD catalogs) - 224 Binary stars, 261 Variable Stars - 388 Stars with known planets - 110 Messier objects, - 103 Caldwell objects - 580 NGC/IC objects - Planets and the Moon - Dwarf planets, large asteroids, - Over 200 observable comets * User objects database with separate module for daytime editing * Object identification around scope pointing direction * List of currently best positioned objects * Display showing RA/Dec, system time, sidereal time and hour angle of scope position * Polar alignment assistant with compass (shows Polaris' hour angle and clock position) * Dew point simulator/estimator * Computes positions of the Galilean moons with GoTo * Rise and set times for Sun (twilight), Moon and the planets * Manual input of equatorial coordinates * Telescope calculator with eyepiece FOV measurement function * Screen night mode with adjustable brightness (as far as the phone allows) * "No-Scope"-mode for use without a mount * Sky Pointer slews the mount to the direction where the phone is pointed (experimental) * Bundled PDF users' manual * microSD card installation System Requirements (user supplied) * Smartphone running Android 2.2 or higher with 1GHz CPU, Bluetooth, GPS, Orientation sensors. * Bluetooth serial adapter hardware * Telescope mount with hand control, either... - Celestron NexStar Hand Control running firmware version 4.13 and higher, or - Celestron NexStar GT hand control running firmware version 4.03 and higher or - SkyWatcher SynScan hand control running firmware version 3.28 and higher. puede que a alguien le interese. Salu2
Publicado 22 de Julio del 201410 a Cris se nececita adaptarle algun hardware al handpad no??, yo tengo una nexstar pero no se como se conectaria ya que en la pagina de celestron no dice nada , tenes idea? Saludos Antes de consultar algo, presentate aca: https://www.espacioprofundo.com.ar/forum/11-club-social-espacio-profundo/ Guias para iniciados: https://www.espacioprofundo.com.ar/topic/32428-normas-del-foro-que-telescopio-comprar-preguntas-y-respuestas/ Tambien podes usar el buscador: https://www.espacioprofundo.com.ar/search/
Publicado 22 de Julio del 201410 a Ale: criswille escribió: System Requirements (user supplied) ... * Bluetooth serial adapter hardware supongo que eso es todo. Los celulares suelen venir con bluetooth. Ese enlace por bluetooth pienso que simula un cable serial. Y ya que con mi EEE PC el cable USB a Serial no me anduvo bien nunca.... podría ser una alternativa un adaptador bluetooth para mi Synscan a ver si logro hacer andar la EQ3 desde el Stellarium. Debe haber también algo tipo WiFi. Sería más práctico, aunque consuma más energía. Saludos! Saludos!
Publicado 22 de Julio del 201410 a Si entiendo el tema es que en la pagina de celestron no hay un adaptador bluetooth o por lo menos yo no lo encontre.... Saludos Antes de consultar algo, presentate aca: https://www.espacioprofundo.com.ar/forum/11-club-social-espacio-profundo/ Guias para iniciados: https://www.espacioprofundo.com.ar/topic/32428-normas-del-foro-que-telescopio-comprar-preguntas-y-respuestas/ Tambien podes usar el buscador: https://www.espacioprofundo.com.ar/search/
Publicado 23 de Julio del 201410 a Hay un par de aplicaciones de Celestron que se llaman "cosmos Celestron Navigator" y "SkyPortal" gratuitas para Android que son ni mas ni menos el SkySafari pero gratis. Si tenes un telescopio compatible con el Celestron Wifi podes controlarlo. No se porque SkyWatcher siendo el dueño de Celestron y Meade no hace lo mismo Ambas estan en el Google Play para descarga gratuita. Saludos y buenos cielos! iOptron CEM70AG, iOptron GEM28ECAskar ACL200, Duoptic ED Pro 60, APO 90, Photo 90 5 elementosQHY600M, QHY294M Pro, QHY268C, QHY183M, QHY5III462CZelaya - Pilar - Buenos Aires - ArgentinaDuoptic - Espacio ProfundoMi Galeria de Fotos IG: @rfcontrerasb
