Publicado 5 de Abril del 20177 a Hola a todos, Este asteroide pasó hoy muy cerca a 11520 km, 0,03 distancia lunar, velocidad 18,48 km/s, tamaño entre 2,8 y 6,3metros. Fuente al pie. Saludos! Mario https://watchers.news/2017/04/04/asteroid-2017-gm/ A newly discovered asteroid designated 2017 GM will flyby Earth at a very close distance of 0.03 LD (~11 520 km / 7 158 miles) from the surface of our planet on April 4, 2017. This is the 15th known asteroid to flyby Earth within 1 lunar distance since the start of the year and the closest one. It is also among the 10 known asteroids to pass this close to Earth ever. 2017 GM belongs to the Apollo group of asteroids. Its estimated size is between 2.8 - 6.3 m (9 - 20 feet). This small asteroid, first observed at Mt. Lemmon Survey on April 3, will make its closest approach to the Earth at 10:31 UTC on April 4 at a speed (relative to the Earth) of 18.48 km/s. [ Ephemeris | Orbit Diagram | Orbital Elements | Physical Parameters | Close-Approach Data ] This is the 15th known asteroid to pass within 1 lunar distance since January 9, 2017, and the closest one. You can find them all in our Near-Earth Objects category. 2017 GM is also one of the 10 known near-Earth asteroids to pass this close to Earth ever. As of March 31, 2017, there are 16 062 known near-Earth objects, 15 956 of them are near-Earth asteroids. 8 696 belong to the Apollo group of asteroids. Since the start of the year, we have discovered 355 new near-Earth objects. All of them are asteroids. The Virtual Telescope Project captured 2017 GM while it was safely approaching us today. "For this, we remotely used a telescope in Arizona, made available to the Virtual Telescope by Tenagra Observatories, Ltd. Above is an image coming from a single 30-seconds exposure, unfiltered, taken with the 16″-f/3.75 Tenagra III (“Pearl”) unit. The Paramount MEII robotic mount tracked the fast apparent motion (150″/minute) of the asteroid, so stars are trailing. The asteroid is perfectly tracked: it is the sharp dot in the center, marked by two red lines," they said. Near-Earth asteroid 2017 GM at 07:34 UTC on April 4, 2017. Credit: Gianluca Masi (The Virtual Telescope Project) and Michael Schwartz (Tenagra Observatories, Ltd)
