Hola gente, les hago una consula por una camara para empezar con el tema del seguimiento
que opiñon les merece esto.?
Desde ya gracias.!
Telescope Camera QHY style Color High Speed for Guiding & Planetary Astronomical
Product Feature:
This camera is a high frame rate Planetary Camera also excellent guide star camera, USB2.0 interface bandwidth to an extreme; ASCOM compatible and WDM framework agreement, dedicated to astronomy software basically done shooting universality; 12 ADC sampling , lossless output, support for RAW, FITS, AVI and other formats,Too aggressive play in post-processing for the astronomical full shooting under.
this camera has accumulated two years of effort, in less than four square centimeters on a piece of board spelled out in good faith use of materials, crystal, tantalum capacitors, CMOS, we have used the best physique, and never for a few cents of profit to save a capacitive multi-patch. From feeding to patch process monitoring, automatic placement machine Siemens guarantees the quality of the patch. Take the amount in exchange for cost reduction, so that every enthusiast can afford is our pursuit!
This camera is professional for planetary Astronomical.
CMOS chips: AR0130
CMOS Size: 1 / 2.5 in.
Effective pixels quantity: 2592 * 1944
Pixel size: 2.2um
Focusing range 20 mm to infinity
Depth of field: 50 mm to infinity
Scintillation control: 50 hz or 60 hz
Readout type: Progressive Scan
Shutter: Electronic rolling shutter
Exposure time: 20us-1min
 the maximum Frame Rate Per Second of this camera is 216
Maximum frame rate:
1280X960@35FPS
1280X720@46FPS
1280X600@55FPS
1280X400@80FPS
960X960@46FPS
1024X768@54FPS
1024X600@69FPS
1024X400@101FPS
800X800@66FPS
800X640@82FPS
800X512@102FPS
800X400@108FPS
800X320@158FPS
640X560@98FPS
640X480@113FPS
512X440@123FPS
512X400@135FPS
480X320@165FPS
320X240@215FPS
2X2Bin:640X480@35FPS5FPS
Binning: 1024 * 768 and 800 * 600 color BIN22
Peak quantum efficiency color: Blue 58% 48% @ 62% @ @ Green Red
ADC digits: 8bit and 12bit (output)
Sensitivity: 1.53V / lu * s (550nm)
Pixel rate readout: 48MHz
Mechanical interface: 1.25 inches eyepiece size (diameter 31.6mm)
Glass window color version with 22mm 680nm IR cut filter
BFL: about 17.5mm (when using the standard C-necked glass window)
Weight :( body only) 45g (excluding the stop ring)
Power Consumption: 0.64W
Guide star Interface: 6-pin RJ11
USB2.0 interface: Yes
Standard Edition: body, stop ring, USB cable, guiding lines, 1.25 prolong tube
Single frame capture storage formats: BMP
Dynamic capture storage format: AVI
Software compatibility support: Windows98, WindowsME, Windows, Windows xp, Windows 7, windows 8 and high version
Hola fedejorge
Cuando decis "para empezar con el tema del seguimiento" entiendo que lo que queres decir es "empezar con el tema del guiado" ya que el seguimiento lo hace propiamente la montura, el guiado ajusta el seguimiento.
Respecto a la cámara, yo preferiría una en blanco y negro ya que al no tener la matriz, tiene mayor sensibilidad lo que ayuda cuando hay pocas estrellas en el campo.
Editado por criswille
1 hour ago, criswille dijo:
Hola fedejorge
Hola @criswille gracias por la info y la explicacion...mira si no estare verde que hasta el vocabulario tengo que aprender.!!
Como dice Cris, para guiado siempre es mejor una blanco y negro. Yo uso una QHY5L-II y hace muy bien su laburo.
