paso los datos para quien desee actualizar
SynScan Firmware (Ver.03.21) Release Note
Date: Feb. 4, 2008
1. Smoother response to manual guiding and PC based autoguiding command.
2. "PC Direct Mode" added. It allolws the PC to communicate directly with the motor controller via RS-232C connection. The RS-232C port of the PC should be configed as 9600bps, 1 start bit, 8 data bits, 1 stop bit, no parity check and no flow control. Activate "PC Direct Mode" under "Utility\PC Direct Mode>". Press the "ESC" key to exit. The 4 direction buttons and rate controlling function operate as usual under this mode.
This feature is also designed for future applications.
link :
http://www.skywatchertelescope.net/swti ... class2=101
