Publicado 13 de Abril del 200816 a Hola a todos Les dejo una copia del informe de fotometria enviado a AAVSO. Es un ejemplo de lo que se logra entre la colaboracion aficionado-profesional. TITLE: GCN CIRCULAR NUMBER: 7580 SUBJECT: GRB 080330 optical observations DATE: 08/04/09 18:36:58 GMT FROM: AAVSO GRB Network at AAVSO A. Block (Seeing In The Dark Internet Telescope, and Steward Observatory, Tucson, AZ) and M. Templeton (AAVSO) report on behalf of the AAVSO International High Energy Network the following observations and analysis of the optical afterglow of GRB 080330 (Mao et al., GCN Circular #7537; Klotz, Boer, and Atteia, GCN #7536): Adam Block reports unfiltered photometry of the GRB 080330 afterglow spanning 2008 March 30.1675 UT to 2008 March 30.3273, taken with the Seeing In The Dark Internet Telescope 14-inch Celestron SCT, using an SBIG ST1001 camera, located near Mayhill, New Mexico. Forty-seven, 300-second unfiltered exposures were obtained beginning 20 minutes post-burst, and continuing through t0 + 0.1736 days. Data acquisition began after the reported peak (D'Avanzo, et al., GCN #7554), but during the early decay epoch. A break in the light curve is apparent at approximately 25 minutes after the trigger; only one data point was obtained prior to this point, and so a slope cannot be reliably derived. After t0 + 25 minutes, the data are reasonably well fit with a power law index of -1.104 +/- 0.001, with a zero point unfiltered magnitude of 22.65 (m = m(t+1day)). However, the light curve appeared to briefly rebrighten by more than 0.2 magnitudes (1-sigma error = 0.09 mag) approximately 70 minutes post-burst, suggesting a late-time manifestation of the rebrightening seen during early light (Schaefer and Guver, GCN #7538). These observations are consistent with other optical observations taken during this time frame; observations through t0 + 250 minutes do not show evidence for the steeper slope described by Sergeev et al (GCN #7556) for data taken at t > t0 + 0.5 days, suggesting this break occurred between the end of these observations and the start of observations by Sergeev et al. A report detailing these observations is available at the following URL: ftp://ftp.aavso.org/grb/AdamBlock_GRB08 ... 33910_.txt The initial image of the GRB field is available at the following URL: ftp://ftp.aavso.org/grb/AdamBlock_GRB08 ... 3910_.fits A light curve of the unfiltered photometry is available at the following URL: http://www.caelumobservatory.com/outgoi ... 330LOG.jpg Photometry and a full description of the observations will appear in the Journal of the AAVSO, and are available from A. Block upon request to ngc1535@caelumobservatory.com. The AAVSO thanks the Curry Foundation for their continued support of the AAVSO International High Energy Network.
Publicado 13 de Abril del 200816 a Marce, asi es como se buscan los exoplanetas no ? La caida de magnitud en el tiempo que se hicieron las tomas es bastante alta, a que corresponde ? Saludos y buenos cielos! iOptron CEM70AG Askar ACL200, Duoptic ED Pro 60, APO 90, Photo 90 5 elementos QHY600M, QHY294M Pro, QHY268C, QHY183M, QHY5III462C Garin - Buenos Aires - Argentina Duoptic - Espacio Profundo Mi Galeria de Fotos IG: @rfcontrerasb
Publicado 13 de Abril del 200816 a Autor Hola Ricky Exacto el proceso es similar a la fotometria que se usa para buscar transitos de exoplanetas, en este caso el muestreo se hace hasta que la fuente desaparece, en al graficco se ve la gran caida de magnitud desde el primer muestreo hasta el ultimo, unos 70 minutos. Saludos Marcelo Rios
Publicado 13 de Abril del 200816 a Marce, excelente material. ¿Conocés cuál es el software que hace el análisis de las imágenes?. En la charla de EP que hiciste, recuerdo que mencionaste que se compara el brillo de dos o mas estrellas contra el brillo de la supuesta estrella en tránsito planetario. Bien vale para binarias eclipsantes también no?. Un abrazo.
Publicado 14 de Abril del 200816 a Autor Leo Algunos de los ptogramas que podes usar ... FOTO DIF, fotometria diferencial para transitos.(español). http://astrosurf.com/cometas/extrasolar ... otodif.htm TELEAUTO, fotometria, captura de imagenes, seguimiento.(ingles - frances). http://teleauto.org/indexEn.php Pequeño tutorial de fotometria con AIP4Win. (español). http://www.x-astro.com/experiencias/Fot ... toComp.htm Espero que te sirva. Saludos Marcelo Rios
Publicado 15 de Abril del 200816 a Entre espectrometría, ocultaciones y transitos exoplanetarios, creo que hay como "para hacer dulce" en materia de campos en los que los aficionados podemos colaborar. Creo que muchos podríamos comenzar a profundizar un poquito y no quedarnos mojándonos los pies en la playa y sacando una y otra vez las mismas fotos, sino aprovechar el equipamiento disponible para algo en lo que se pueda aportar científicamente. -(me incluyo plenamente y por supuesto esto es para quien le interese) Gracias Marcelo por enriquecer el foro
Publicado 15 de Abril del 200816 a Es verdad Marcos, me incluyo para dar un paso entre las olas, es un tema en el que deberíamos profundizar y meternos, creo que la comunidad está preparada para esto. Abrazo
Publicado 15 de Abril del 200816 a Que laburito Marcelo, la verdad que estas aportando mucho dato util al foro, te felicito y espero que sigas asi... Un abrazo!
Publicado 16 de Abril del 200816 a Aprovechando el post consulto, que herramientas debemos poseer para poder realizar estas investigaciones?
