Vendo Cámara QHY268-C Nueva en caja
amanecer
Cámara QHY268-C (Color) Recién traída de USA. SIN USO! Nueva en caja.
Cero AMP GLOW. Sensor APS-C con 90% de eficiencia cuántica. 16 Bits (65535 escalas de grises).
Precio: u$s 2800
Se encuentra en Buenos Aires. No tomo canje. Pagos en efectivo.
Model QHY268C
CMOS Sensor MSONY IMX571 C
Pixel Size: 3.76um x 3.76um
Effective Pixel Area: 6280*4210 (includes the optically black area and overscan area)
Effective Pixels: 26MP
Sensor Size: APS-C
A/D Sample Depth
Native 16-bit (0-65535 greyscale) A/D
Full Well Capacity (1×1, 2×2, 3×3)51ke-
75ke- or above in extended full well mode
Full Frame Rate USB3.0 Port:
Full Resolution  6.8FPS  @8BIT         6FPS @16BIT
2048lines         13.6FPS  @8BIT     11.5FPS@16BIT
1080lines         25.4FPS  @8BIT     19.5FPS@16BIT
768lines           35FPS     @8BIT        25FPS@16BIT
480lines           50FPS     @8BIT        34FPS@16BIT
Readout Noise 1.1e- High Gain, 3.5e- Low Gain
(5.3e- to 7.4e- in extended full well mode)
Dark Current: -20C,0.0005e /pixel/sec -10C,0.001e /pixel/sec
Exposure Time Range: 30us-3600sec
Amp Control Zero Amplifer Glow
Firmware/FPGA remote Upgrade: Fully support via Camera USB port
Shutter Type Electronic Shutter
Computer Interface USB3.0
Built-in Image Buffer 1GByte DDR3 Memory
Cooling SystemTwo-stage TEC cooler
Less than 1S lower than ambient temperature -30C in continuous mode
More than 1S continuous mode or lower than ambient temperature -35C in single frame mode
Optic Window Type AR+AR High Quality Multi-Layer Anti-Reflection Coating
Anti-Dew Heater Yes
Telescope Interface Support M54 and M48 (with standard adapters )M54/0.75(with CAA) and M48 (with standard adapter)
Weigth 780g
Contacto por WhatsApp a:
+5491150071117
Algún editor que lo mueva a la categoría correcta de Cámaras. Por error lo publiqué en telescopios.
Post movido automáticamente al vender/suspender producto.
Muchas gracias.
Javier Iaquinta
Crear una cuenta
Registrar una nueva cuenta
Conectar
Conectar ahora
  • Crear nuevo...
