Publicado 3 de Enero del 201015 a No sabía cómo poner el asunto así que le puse así nomás. Este programa, a partir de una imagen que uno haya tomado del cielo, detecta automáticamente a qué constelación pertenece y la ubica en el cielo, dando todo tipo de información pertinente. Así de fácil. El programa está en testeo y se le puede mandar un mail al que lo desarrolló para testearlo. http://larryo.org/work/information/unimap/index.html
Publicado 4 de Enero del 201015 a eduardo parece mas que bueno el programa, hace algun tiempo vengo usando uno similar, si bien no es complejo de calibrar lleva su tiempo. http://www.astrosurf.com/pulgar/elbrus/elbrussp.htm saludos
Publicado 4 de Julio del 201014 a You can download and test the very first pre-alpha release from here: http://larryo.org/work/information/unimap/download.html I know there are still bugs and room for of improvements, optimization, etc. "Unfortunately" I have built this application so big for so little time I’ve got that I should probably be focusing on getting the a core functionality working right and here any suggestions and ideas will really help. Larry
Publicado 10 de Octubre del 201014 a Version 0.0.2 pre-alpha is now available for download from: http://larryo.org/work/information/unimap/download.html Larry
Publicado 11 de Octubre del 201014 a You can download and test the very first pre-alpha release from here:http://larryo.org/work/information/unimap/download.html I know there are still bugs and room for of improvements, optimization, etc. "Unfortunately" I have built this application so big for so little time I’ve got that I should probably be focusing on getting the a core functionality working right and here any suggestions and ideas will really help. Larry Thanks for the info, Larry and welcome to "Espacio Profundo" forum. This is a forum for Spanish speakers. So... I will translate your post so that everyone can understand. Regards -- Al parecer Larry es el creador del software y, mas o menos, dice que es consciente que el software tiene algunos errores y cosas por corregir, que "desafortunadamente" construyó la aplicación en muy poco tiempo. Probablemente debería enfocarse en conseguir que las funcionalidades básicas funcionen correctamente y que en ese punto todas las ideas y sugerencias son bienvenidas. En fin, si alguno tiene alguna idea o sugerencia y tiene ganas de postearla... después alguno de los que nos defendemos con el inglés podemos intentar traducirla. Saludos
Publicado 11 de Octubre del 201014 a Ayer le envie un privado a Larry ofreciendole traducir el software, me respondio que esta armando las cadenas de texto en ingles para que podamos traducirlas, como hicimos con el DeepskyStacker, alguno se anota para colaborar con la traduccion/revision? Saludos y buenos cielos! iOptron CEM70AG, iOptron GEM28ECAskar ACL200, Duoptic ED Pro 60, APO 90, Photo 90 5 elementosQHY600M, QHY294M Pro, QHY268C, QHY183M, QHY5III462CZelaya - Pilar - Buenos Aires - ArgentinaDuoptic - Espacio ProfundoMi Galeria de Fotos IG: @rfcontrerasb
Publicado 11 de Octubre del 201014 a a las ordenes suyas para cuando gusten comenzar con la tarea horacio
Publicado 11 de Octubre del 201014 a Ayer le envie un privado a Larry ofreciendole traducir el software, me respondio que esta armando las cadenas de texto en ingles para que podamos traducirlas, como hicimos con el DeepskyStacker, alguno se anota para colaborar con la traduccion/revision?Saludos y buenos cielos! Si, obvio Rick. Cuando tengas todo repartimos!
Publicado 13 de Octubre del 201014 a Sería bueno repetir la labor. Sumo mi aporte, humilde por supuesto
Publicado 29 de Mayo del 201113 a Version 0.0.3 pre-alpha is now available for download from: http://larryo.org/work/information/unimap/download.html Larry
Publicado 29 de Mayo del 201113 a I have also added two small video tutorials (basic) here: http://larryo.org/work/information/unimap/support.html I am not sure if this format is ok, feedback will help before I go on to make better tutorials. Larry
Publicado 16 de Septiembre del 201113 a Mi señora es traductora aunque veo que no se les va a complicar. Pero cualquier cosa avisen.
